OctaneRender for Maya 2023.1-22.7 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2019, 2020, 2022, 2023 and 2024 64-bit on Windows, MacOS and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
Changes since version 22.5:
  • Integrated the 2023.1 first stable engine.
  • Fixes and improvements...
NOTE: Directional light in current 2023.1 Standalone is not affected by its parent transform rotation at all. This is why you can only rotate this light in Maya by a transform node connected to this light-node's "Transform" plug. At least for current Octane engine version...
NOTE: For the current version: if you're running on macOS m1/m2, please enable Rosetta under "Maya app > Info".
NOTE: Don't forget to use the %p tag where you need the AOV-name to appear in the output path. I've found out that this has not been mentioned in the plugin manual, but it's going to be better described soon...
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
Locked
