Remap texture paths
Davve
I'm trying to figure out how to change textur dir. I swapped my drive letter and now my texture paths are broken.
Any easy fix for this?
Cheers
David
Hesekiel2517
Hi Davve,
best way to work with texture imho is to load them just as usual in Modo and then drag the texture into the schematic. Now connect the filename to the filnename input of the image node. This way modo will handle the urls if a paths changes.
Davve
Hesekiel2517 wrote:Hi Davve,
Thank you for this, will try it out!
Cheers
D
Return to “Foundry Modo”
