OCTower
t_3
...this is more a DYI WIP than an octane render WIP, but the latter too.
early stages (concept wise and render wise) of an overclocked octa-gpu octanerender tower i'm going to build over the winter.
it'll sport 8 3gb msi lightning extreme cards (each with at least 75% performance of a standard gtx 590).
two 1800 watt power supplies, a msi big bang marshal board width a i7 2600k cpu (watercooled) and 16gb ram.
the mechanical concept should allow every heating component breathing lots of fresh air,
while maintaining a still compact size (footprint will be 36x24cm, 72cm tall);
also it will be possible to swap cards really easy to upgrade the box.
an extra benefit should be, that it could be used as an oven during winter...
cornel
this will cause the city´s next blackout! :shock: I´m sure.
Win 7 x64 | GTX770 Phantom 2GB | Phenom II X6 3.2GHz | 16GB
Jaberwocky
Next thing you know , he'll be asking pixar if they have any feature films coming up that they would like rendered. :o
t_3
Jaberwocky wrote:Next thing you know , he'll be asking pixar if they have any feature films coming up that they would like rendered. :o
i'd like better if they order around 150 such towers, so i can quit my daytime job ;)
face
For that, a quadro6000 rig would be better ;)
face
http://vimeo.com/user2509578
t_3
face
...well, i'm a modest guy 8-)
Refracty
Cool, you had the same idea with the riser cables :)
I hope this tower will come to 'live' soon.
afecelis
droooooooooling! 8-) 8-) 8-)
What are the price numbers for something like this? BTW, the concept render looks nice.
BTW2, have you met helmer? ;)
http://helmer.sfe.se/
Though its more cpu-power oriented, it's always an interesting read.
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
t_3
afecelis wrote:droooooooooling! 8-) 8-) 8-)
...putting a cpu cluster into an ikea drawer is freaky2themax :)
but as i started with luxrender into unbiased rendering, i already have some boxes for network rendering ;) btw built with this case http://www.silverstonetek.com/product.p ... 1&area=usa which has a very good airflow and allows a nice line-up of a few boxes side by side. it'll even take 1 or 2 gpus while still maintaining fair temperatures.
the components for my gpu-tower will be around 6k euro (with taxes), and i hope another 1k will make me the "case", including (external) material processing, laser cutting, whatsoever...
Return to “Works In Progress”
