OctaneRender™ for Blender 2023.1.Beta.3 - 28.3 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Support "Shade Flat" feature
  • Provide an option in the preferences panel, deciding whether to use the new "Factor" subtype for properties(like Cycles), or the legacy slider style
  • Reorganize the passes in the Render AOV and add a search option
  • Rename and hide the Octane Helper node graph in the GUI
You can read about new features of OctaneRender™ 2023.1 Beta 3 here:
viewtopic.php?f=33&t=82021
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.3 (3.6.2)
Octane Server - Studio+ Edition - 28.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 28.3
