OctaneRender™ for Blender 2023.1.Beta.3 - 28.2 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Update to Octane 2023.1.Beta.3
  • Update to Blender 3.6.2
  • Support the new kernel workflow(migrated from the addon version)
  • Support the mute connection feature
FIXES SINCE LAST RELEASE
  • Fix the Vectron crash
  • Fix the render layer update issue
  • Fix the animation setting update issue
  • Fix the kernel initialization issue
  • Fix the octane compositor crash
  • Add hints when using deformation motion blur on objects with auto smooth enabled
You can read about new features of OctaneRender™ 2023.1 Beta 3 here:
viewtopic.php?f=33&t=82021
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.2 (3.6.2)
Octane Server - Studio+ Edition - 28.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 28.2
