Octane 2022.1.2 for Unreal Engine - 0.69
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine
Changes:
  • Upgraded to Octane 2022.1.2
  • Added support for light function scaling
  • Improved octane to unreal material graph conversion (used when importing ORBX files)
    Added support for the following Octane nodes: Floats to color, Float3 to color, Float to grayscale, Channel Inverter,
    Channel Mapper, Channel Merger, Channel Picker, Color Conversion, Position, UV Coordinate, HSV to RGB, RGB to HSV.
  • Added barndoors support for Rect Lights
Fixes:
  • Fixed issues with possible lingering/duplicate scene objects when using the sequencer in unreal
  • Fixed issue with possible lingering/duplicate scene objects when switching scenes
  • Fixed transparency being inverted for certain types of translucent materials
  • Fixed transparency and refraction being incorrect when refraction is not actually used in unreal material
  • Fixed material compilation crash when shading model is not correctly set in shader
  • Fixed ORBX export crash when export is initiated during beginplay in blueprints
  • Fixed possible material compilation crash when normalize has a incorrect input
  • Fixed no square falloff for spotlights
  • Fixed small memory leak when using MRQ ORBX export
UE 5.2
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_2.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_2.exe
