Noise makes Cinema Octane Freeze
Conna3005
I use a Noiseshader as a Bump Map.
If i want to Setup, and make many corrections the Live Viewer Crashes anhd the whole Program Freezes.
I dont use Displacement. Bump is Easier. Beside that i am using a Noise Shader and i cannot get a Good Result.
If i want to Set the Walls with a Wallpaper what should i do ? I need it like a real Wallpaper. Is there any Tutorial for that ?
If you got anjy advise then Tell me.
Don't use C4D shaders. We have octane noise nodes, 4d noises for example. Give a try
