invalid ID A_COMPATIBILITY
dermotfaloon
Trying to get the bottom of this message in the LOG.
'Tried to access attribute via invalid ID A_COMPATIBILITY_VERSION (438)'
I use a template C4D scene as my startup the way I like to start an octane job.
If I make a blank scene without 'new.c4d' and add a few objects etc and render the message 'Tried to access attribute via invalid ID A_COMPATIBILITY_VERSION (438)' doesn't show.
If I paste in my scene bits and camera etc into here and render then it shows again?
There is a function that's trying to access this attribute which is unavailable. It's not a message that should be worried about. What's your problem with it?
dermotfaloon
Thanks for the quick reply Aoktar, I was troubleshooting a job which had issues, (x-particles) on certain frames.
I thought this message was partially responsible until I started working on blank and basic scenes.
I realised it shows up as soon as you add a material the message is duplicated per material.
If its normal and nothing to worry about that's fine - at least this post may be helpful to others when troubleshooting.
It will be fixed but that's not a critical message for the users. Just for developers
