OctaneRender™ for Blender 2022.1.2 - 27.17 Final Release [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Upgrade to Blender 3.6.1
  • Upgrade to Octane 2022.1.2
FIXES SINCE LAST RELEASE
  • Minor Bug Fixes
You can read about new features of OctaneRender™ 2022.1.2 here:
viewtopic.php?f=24&t=81949
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.17 (3.6.1)
Octane Server - Studio+ Edition - 27.17
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
