OctaneRender™ for Blender 2023.1.Beta.2 - 28.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Update to 2023.1.Beta.2
  • Implemented the cryptomatte picker
  • Adjust the GUI of the kernel panel
FIXES SINCE LAST RELEASE
  • Fix the no render progress problem when "Keep Environment" and "Has Alpha" are enabled
  • Fix the issues about the legacy render pass panel
  • Fix a shared surface bug when rendering Z-Depth
  • Set the default object type as "Scatter/Movable"
You can read about new features of OctaneRender™ 2023.1 Beta 1 here:
viewtopic.php?f=33&t=81943
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.1 (3.6.1)
Octane Server - Studio+ Edition - 28.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
