Octane Scatter Effect Decay Question
Choe
Hello
While using the field through Octane Scatter, I tried using decay, but it is not recognized.
Is there a solution?
I want the object to be maintained using decay when the field passes on the octane scatter. have a nice day! :D
in short, better to use MoGraph Cloner in Render-Instance mode with time effects.
ciao,
Beppe
BrianSandoval
Thank you bepeg for your suggestion, I also had this question
mojangfair
To sum up, temporal effects in Render-Instance mode in MoGraph Cloner are the way to go.
grincharray
mojangfair wrote:To sum up, temporal effects in Render-Instance mode in MoGraph Cloner are the way to go.dinosaur game
I will try it.
