OctaneRender™ for Blender 2023.1.Beta.1 - 28.1 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Implemented the cryptomatte picker
  • Fixed the no render progress problem when "Keep Environment" and "Has Alpha" are enabled
FIXES SINCE LAST RELEASE
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1 Beta 1 here:
viewtopic.php?f=33&t=81840
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.1 (3.6.1)
Octane Server - Studio+ Edition - 28.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
