OctaneRender™ for Blender 2023.1.Beta.1 - 28.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to Blender 3.6.1
  • Upgrade to Octane 2023.1.Beta.1
  • New 2023.1.Beta.1 features:
    • Compositor
      • Support the new Octane Compositor with dozens of new nodes
      • Add Composite texture adjustment layers
    • Geometry
      • Support Animation time transform for Orbx Proxy(Property Panel - Data - Orbx properties)
      • Add the new Post volume effects panel(sitting below the old post process panel)
      • Add new options to the Octane Volume
    • Light
      • Add the new Octane Directional Light
      • Add the new Octane Analytical Light
    • Kernel
      • Now we use "Node Tree" for the Kernel settings.
      • The legacy settings will be converted to the new node tree automatically.
      • Along with a "Legacy Kernel Converter" that can convert an old preset into a new kernel node tree.
    • Render AOV
      • Add light IDs 9 to 20 for light linking
      • Add Postfix media pass
      • Fix some issues of the legacy render panel and passes
    • Render settings
      • Add new options to the Postprocess panel and relayout the GUI
    • Octane Export
      • Update to the Octane 2023.1.Beta.1
      • Implementation of exporting jpeg and tiff
  • Add a set of "Switch nodes" for switching between different targets
  • Update to new enum Gradient interpolation type
  • Add diffuse BxDF type to Universal and Glossy materials
  • Dozens of updates according to the Octane 2023.1 changes
  • Update of the Blender Presets for the render passes, imager, and postprocess
FIXES SINCE LAST RELEASE
  • Various Minor Bug fixes
You can read about new features of OctaneRender™ 2023.1 Beta 1 here:
viewtopic.php?f=33&t=81840
1. OctaneRender™ Server
Windows
Blender Octane Edition - 28.0 (3.6.1)
Octane Server - Studio+ Edition - 28.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
