z depth and plants - not right
jwfvr
hi - I have a scene with various plants and a few of them are showing up too bright in regular beauty pass, and they also show up in the z depth pass- even though they are in the foreground in this case - they are single sided planes, everything in the material is what I usually do - nothing special, is there any known cause of this? the other plants in the same scene do not have this issue.
I would need to see the scene in order to be able to offer any explanation/solution.
jwfvr
right - this scene is huge and when I try to replicate it in a smaller one to send over, the problem doesn't show up... if I can get it to happen again I will send thank you
jwfvr wrote:right - this scene is huge and when I try to replicate it in a smaller one to send over, the problem doesn't show up... if I can get it to happen again I will send thank you
OK. Sometimes rendering out the other render passes can give a clue to what is going on. For example, wireframe, Object ID, position, etc. Also - if the scene is massive - is it possible you are running out of memory?
jwfvr
not running out of memory, but after playing with the surface particle generator, the problem went away. no idea why...
Return to “Foundry Modo”
