Octane lag after completing a region render
Dingbat
i've noticed that if i do a region render and the render completes (in my case with denoising), when i try to restart the render by pressing play again, changing something etc, Octane is unresponsive and laggy and when the render does get going again it's way slower than before (10x slower or worse)
i have to stop/start/reload the render to respond again but this wastes a lot of time as it takes a while for the scene to reload
if i make changes before the render completes (even if doing a region render) everything works as normal
of course i need to complete the render to get the denoised image
hope that makes sense
Hi - I wasn't able to reproduce this issue, although I am no certain the exact workflow you are using. I didn't think a region render ever finished - it just keeps going. Is Imager->Denoise on Completion enabled? If the region render never completes, then denoising wouldn't happen is Denoise on Completion was ticked. Could you post a video showing what it happening please?
Dingbat
thanks Paul
it's quote random so unfortunately there's no single thing i can point to that is the definite issue
however i will say that AFAICT when doing a region render in MODO when the render completes it usually stops (i used the Standalone a couple of times and i think it carries on there?). sometimes though it gets stuck and becomes more erratic or, worst case, unstable
i'm not sure but it might be something to do with the issue that Funk pointed out that a 3d window must be visible in the layout for the model to be correctly updated
have been doing region renders today with 3d window visible and so far so good - render is stopping when specified samples reached, and render restarting as expected when i change something
will update if something changes
Return to “Foundry Modo”
