OctaneRender 2022.1 for Houdini production build 2022.1.1.1
toby_a
This is a production release of the OctaneRender™ 2022.1 for Houdini™ plugin compiled with the Octane 2022.1.1 core. This 2022.1.1.1 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 18.5.759, 19.0.720, 19.5.534, 19.5.569, 19.5.605, and 19.5.640 (the latter using the 19.5.605 build).
New features
To learn more about the new features and improvements of OctaneRender 2022.1.1, please check out the 2022.1.1 release post
Downloads
NOTE: This release is structured as one download for each combination of platform, Houdini version and Octane license type. Previous releases had multiple Houdini versions bundled into a single download. Hopefully, the new way is more convenient due to smaller downloads, but please let us know if you prefer the old way.
Release 2022.1.1.1 Studio+ license
Windows Houdini 18.5.759 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.605 and 19.5.640 - https://render.otoy.com/customerdownloa ... _Win64.zip
Linux Houdini 18.5.759 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.560 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.605 and 19.5.640 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Release 2022.1.1.1 macOS Prime license
MacOS Houdini 19.5.534 -
https://render.otoy.com/plugindownloads ... _Prime.zip
MacOS Houdini 19.5.569 -
MacOS Houdini 19.5.605 and 19.5.640 -
Release 2022.1.1.1 Demo version
Windows Houdini 18.5.759 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.5.605 and 19.5.640 - https://render.otoy.com/plugindownloads ... _Win64.zip
Linux Houdini 18.5.759 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.5.605 and 19.5.640 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Standalone 2022.1.1 version for the network rendering nodes
viewtopic.php?f=24&t=81415
Release Notes
RELEASE 2022.1.1.1
* PLUGIN FEATURES AND FIXES:
- Added H19.5.605 plugin builds; removed H19.5.493.
- Fixed crashes caused by multi-threaded scene extraction.
- Enabled multi-threaded scene extraction on macOS.
- Fixed spelling of "ambient occlusion" in the render target HDA.
- Fixed an issue with volumes that contain half-resolution grids.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package.
Happy rendering,
Your OTOY Team
tripledistilled
While I can get the macOS Houdini 19.5.569 plugin to run. 19.5.605 and 19.5.640 don't seem to work at all on macOS?
They don't even flag up the usual security warnings that appear when running a plugin that has not been notarised by Gatekeeper properly.
The IPR window throws up the following: There is an error in the Octane Qt5 IPR script. - this usually appears when a plugin hasn't been given permission to run, but no permission dialog ever appears.
No clue what this means? Am I missing libglut.so.3? Like I said, 19.5.569 is working fine.
tripledistilled
Update: Figured out I was running the Intel / Rosetta version of 19.5.640 by mistake. I have it working now, phew.
For whatever reason, the Apple Silicon version of Houdini has never run from the Houdini Terminal.app - making it harder to debug.
lavrenovlad
Thanks for the release! Full-Reload Multi-Threaded scene extraction crashes aren't a pain anymore hopefully
toby_a
lavrenovlad wrote:Thanks for the release! Full-Reload Multi-Threaded scene extraction crashes aren't a pain anymore hopefully
Fingers crossed!
timcgi
Is there a release date for the 2023 Build of Octane for Houdnini?
ryanaexavier
What is the release plan for 2023?
ricky_otoy
Hi, we should have a beta build of 2023 out for you in about a week or two.
