Octane buffer pixel value read out?
Dingbat
is there a way to check pixel values in the buffer when rendering?
Hi - you can either use the octane.copyRenderToClipboard command and paste into Gimp, Photoshop, etc. Or I can add a function to the python interface of the plugin to allow you programmatic access to the render buffer.
elsksa wrote:That, while viable, would limit to integer encoding/file format (conformed to output destination) "picked values".
Sorry, I am unclear what you are saying here. The current format that is saved to the clipboard is QImage::Format_RGB32 (https://doc.qt.io/qt-5/qimage.html#Format-enum). In theory any of the formats could be used, although I have not tried them.
Thank you for the elaboration.
I was making the assumption that it was on-par with the Copy-To-Clipboard from Octane-Standalone, limited to a PNG file format (integer "LDR"). I suppose it is rather the equivalent to the nearby icon (quick "save the current render to disk").
Yes, the plugin is also copying the render to the clipboard in LDR format.
Dingbat
face_off wrote:Hi - you can either use the octane.copyRenderToClipboard command and paste into Gimp, Photoshop
that's what i currently do but it's a bit clunky when you want to quickly check and adjust a few colours, or check clipping
not the end of the world but would be very handy to have
or a histogram?
Dingbat
elsksa wrote:There are no such issue as "clipping" with a proper color pipeline
thanks
i get that but sometimes Octane tonemapping (in the frame buffer) is all i need and more often than not i prefer it to both ACES and Filmic tonemapping
i found this tool from MS - not ideal but at least i can check things much more quickly:
https://learn.microsoft.com/en-us/windo ... lor-picker
Return to “Foundry Modo”
