OctaneRender for Maya 2022.1.1-21.27 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2019, 2020, 2022, 2023 and 2024 64-bit on Windows, MacOS and Linux systems.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
Changes since version 21.26:
  • Tonemapping fixes/improvements.
  • Implemented legacy PNG gamma (bake) support in all image textures.
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
hgarrou
DO NOT INSTALL!!!
I can't get it to uninstall! Need help ASAP.
Windows add Remove programs starts the process then it just "dumps" into no window, no response. Attached a capture of the last interface seen.
I need this uninstalled immediately. Thanks in advance for any help.
BK
hgarrou wrote:DO NOT INSTALL!!!
Hi hgarrou,
Thank you so much for reporting this.
We are able to replicate it and will replace a new Windows build asap!
cheers
Kind Regards
bk3d
BK
Hi hgarrou,
We have replaced the link above with a new one.
Please run this build then try uninstall.
cheers
Kind Regards
bk3d
hgarrou
That's not the right file, you've linked to Studio standalone, not the VR plugin for Maya.
BK
hgarrou wrote:That's not the right file, you've linked to Studio standalone, not the VR plugin for Maya.
Hi hgarrou,
The VR is usually Studio license and now Studio+.
Would you please try to download and let us know how it goes?
cheers
Kind Regards
bk3d
zurakan
i have issue when i use batch render seq renderlayers is not correct name of layers in output filename
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
BK
zurakan wrote:i have issue when i use batch render seq renderlayers is not correct name of layers in output filename
Hi zurakan,
thank you for reporting this issue.
We are able to replicate it on our side and hope to fix asap!
cheers
Kind Regards
bk3d
hgarrou
Uninstaller works nnow, thanks for the update.
Locked
