OctaneRender™ for Blender 2022.1.1 - 27.16 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
Note: This Stable Release is the non-Addon based version of 27.16, still using a Custom Build of Blender.
  • Update to Blender 3.5.1
  • Implement the new addon-style Octane Output panel
  • Implement the new addon-style Render Pass panel
  • Implement the new addon-style Mesh Light and Sphere Light
  • Implement Octane Spotlight
  • Add "Prefer Image Type" in the Render properties panel
FIXES SINCE LAST RELEASE
  • Fix the smooth normal bug
  • Fix the camera motion blur bug
  • Updates for the addon compatibility
You can read about new features of OctaneRender™ 2022.1.1 here:
viewtopic.php?f=24&t=81415
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.16 (3.5.1)
Octane Server - Studio+ Edition - 27.16
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
