Network Render udating every frame
Turck
Is it normal that the NetRender needs to update the scene for every frame?
I have C4D/Octaner running with 2 other workstations as render nodes. My thought was it would need to upload the scene once to the render nodes.
Yes, it is normal, unless you have a Camera animation only scene.
It needs to load the difference in animation data frame by frame.
Please go to Render Settings/OctaneRender/Main tab and check that the Geometry Engine is set to Render Only Updated Objects, and the Geometry Control is set to All Objects Movable.
ciao,
Beppe
Turck
Okay, thank you.
