Combined and Shadow pass in one rendering?
Andreas_Resch
Hello.
I'm on the next stage of exploring Octane and have arrived at render passes. Here's a question. Is it possible to have a "normal" pass (containing) all the objects and the shadow pass in one rendering like in the image below? I know it's possible to use render layers, but that would mean twice the render time. And as I usually render very high res images (8K+) this is a significant amount of time. Thanks for any advice.
Andreas_Resch
Thanks for the reply.
In Cycles it is possible to get those two passed in one render run. That's why I asked.
About render layers. From what I understood, the render process starts from scratch for each render layer. If there's a way to get multiple render layer in one render run, that's great. I'll look for more information about that.
And no - I was not talking about single-file vs. multiple files. I'm fine with multiple files. Used them in Cycles as well.
linograndiotoy
How do you do this?
AFAIK, you need to render the scene twice in Cycles as well, using view layers.
Which can be done in Octane as well.
View_Layers.blend
(1.23 MiB) Downloaded 129 times
Andreas_Resch
It's possible in one render run. If the "Shadow Catcher" is activated as a render pass, the objects and the shadow catcher are separated like this. Here a plane is below the sphere and it's marked as a shadow catcher in the object settings.
But I guess I can come to a similar result if I extract the objects from the combined layer with an object mask.
linograndiotoy
Andreas_Resch wrote:It's possible in one render run. If the "Shadow Catcher" is activated as a render pass, the objects and the shadow catcher are separated like this. Here a plane is below the sphere and it's marked as a shadow catcher in the object settings.
In your previous example the shadow were not masked by the obejct, that's what I was thinking you needed.
Andreas_Resch
Yeah. That's not possible in Blender either. Not in one run. But I think I will go for extracting the objects from the combined pass. I hope I don't get any issues around the corners.
J.C
This might be useful but not exactly what you wanted.
https://www.youtube.com/watch?v=bEgjnyNwOSg
System – Windows 11
Andreas_Resch
Thanks, JC. I've watched this video before (and many more of Silverwing :)) But I will do it again when I deep-dive into all my export options.
Return to “Blender”
