OctaneRender for SketchUp 2022.1.1-1.0[OBSOLETE]
BK
Otoy® is proud to announce the availability of a new Refactored version of OctaneRender™ for SketchUp® 2021, 2022 and 2023.
The world's fastest and most feature-rich unbiased render engine that integrates complete SketchUp and native features.
For example, Shadows, Layers, Native material picker, Automatic material converter, Data sync, etc.
Version Requirements
This release will work with SketchUp® Versions 2021, 2022 & 2023 64-bit on MS Windows and macOS 12 & 13.
Standalone 2022.1.1 Stable version for the network rendering nodes
viewtopic.php?f=24&t=81415
Change log since the last release
  • -Upgrade to Octane 2022.1.1
    -Support SketchUp 2023
    -Fix the freezing issue when using the material picker
    -Fix the transparent material issue
    -Fix the material save issue
Please note: If there is any missing texture in the render, then make sure the material is existed/listed under In Model.
Exploding the groups would fix this issue.
No LiveDB for macOS build since we are using prime tier.
Downloads
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS-related issue that causes a render failure consistently if you render for long periods of time.
OctaneRender for SketchUp Prime macOS
[For Trimble Sketch 2021 macOS 13]
[For Trimble Sketch 2022 macOS 13]
[For Trimble Sketch 2023 macOS 13]
OctaneRender for SketchUp Studio+
[For Trimble Sketch 2021 Windows]
[For Trimble Sketch 2022 Windows]
[For Trimble Sketch 2023 Windows]
OctaneRender for SketchUp Demo
Happy GPU Rendering!!
Sincerely yours
OTOY
Kind Regards
bk3d
