OctaneRender™ for Blender 2022.1.1 - 27.15 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Upgrade to Blender 3.5
  • Update the Octane link validity checker
  • Re-layout nodes' enum properties
  • "Export Octane Blender Addon" feature also converts node groups
  • Stop preview rendering automatically when a final render session is started
  • Use "2x2" as the default value of the Subsampling mode
  • Use "3D transform" as the default node type instead of the "Transform Value"
  • Change the Mode to "Accurate" as the default setting for Round Edges
  • Enhance Cycles material converter
FIXES SINCE LAST RELEASE
  • Fix the rendering issue when changing the Blend Weight values of the Mix Displacement node
  • Fix the wrong node type issue when using the search operator
  • Fix the crash of adding octane nodes in the geometry node editor
  • Fix the device preferences issue
  • Fix the infinite plane rotation issue
  • Fix Z-Depth pass rendering issue when the shared surface is on
  • Disable UpSampler when the shared surface is on
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2022.1.1 here:
viewtopic.php?f=24&t=81415
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.15 (3.5)
Octane Server - Studio+ Edition - 27.15
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
