Render Volumes Option ?
Hydra Solaris
Creative_Sheep
Rendering Volumes in Octane require the user to toggle on volume primitives for Octane tab for the Object; although how does one do the same when using Solaris as to render volumes when the object was creating in Solaris using SopCreate LOP ?
peteg
I think Octane Solaris might still require the volume saved to disk as a vdb, then loaded using the LOP "Volume" node. Hope they'll add the option of rendering those without the extra step at some point.
BK
Creative_Sheep wrote:Rendering Volumes in Octane require the user to toggle on volume primitives for Octane tab for the Object; although how does one do the same when using Solaris as to render volumes when the object was creating in Solaris using SopCreate LOP ?
Hi Creative_Sheep,
Thanks for the post.
At the moment we would need to write out as VDBs and then use the Solaris VDB node.
Would you please share a sample scene of the SOP workflow?
cheers
Kind Regards
bk3d
Creative_Sheep
Hi Creative_Sheep,
cheers
Hi, I've attached the scene file; as well, how can I bake out the negative values of a VDB an image map ?
Return to “Hydra Solaris”
