Device preferences bug
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Fredrikvictorhugo
Hi. When I deselect a card in device preferences and close it the card still is used when rendering in the latest build.
That isn’t the case in the earlier release. Someone else having the same problem.
I use windows 10.
/Fredrik
linograndiotoy
Hi! That's due to the new "Use Share Surface for Viewport" option (you can find it in the Octane addon settings).
Just disable it for now.
Thanks for reporting this!
Fredrikvictorhugo
Hi! I disabled the new "Use Share Surface for Viewport" option and that didn`t fix it. The problem is the same as before.
Did that work for you?
I have a gtx 1080ti for the Display and render with a 3090.
/Fredrik
linograndiotoy
Fredrikvictorhugo wrote:Hi! I disabled the new "Use Share Surface for Viewport" option and that didn`t fix it. The problem is the same as before.
/Fredrik
Yes it did. By the way, we've fixed the issue already, and a new build will be available soon.
Return to “Bug Reports”
