OctaneRender™ for Blender 2022.1.1 - 27.12 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
  • Upgrade to Octane 2022.1.1
  • Support using the shared surface feature on multiple-GPU platforms
  • Add "Static noise" in the Info Channel Kernel
  • Add "Perspective correction" in the universal camera
FIXES SINCE LAST RELEASE
  • Fix background rendering crash
You can read about new features of OctaneRender™ 2022.1.1 here:
viewtopic.php?f=24&t=81415
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.12 (3.4.1)
Octane Server - Studio+ Edition - 27.12
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.12
