connecting node to a nodegraph
Forum for OctaneRender Lua scripting examples, discussion and support.
gah5118
I am trying to connect an alembic nodegraph inside an orbx nodegraph to a output geometry node
I have tried a few ways but am just beating my head against the wall at this point. the last method I was attempting was to have it create the output node in the selected graph, then clear the selection and select the output node along with the geometry.abc node. up to this point is successful, but getting the two to connect just doesn't want to work out. I have been able to connect standard nodes, but the error "[string "setupscript.lua"]:60: bad argument #1 to 'connectTo' (octane.node expected, got octane.nodegraph)" comes up when trying to connect it to the alembic node.
outlink = octane.node.create{ type=octane.NT_OUT_GEOMETRY, name="output", graphOwner=octane.project.getSelection()[1] }
obg = octane.project.getSelection()[1]:findItemsByName("geometry.abc")
print_table(obg)
octane.project.clearSelection()
octane.project.select(outlink)
octane.project.select(obg[1])
print_table(octane.project.getSelection())
--outlink:connectTo(octane.project.getSelection()[1],)
octane.node.connectTo(octane.project.getSelection()[1],octane.project.getSelection()[2])
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
gah5118
figured it out finally... my code is below. it's a mess and has a lot of my print test to understand how the commands were behaving. hoping it might help someone in the same situation.
function print_table(table, str)
    --print a table plus an optional extra string
    for i,n in pairs(table) do
        print(i,n)
    end
    print(str)
end
function rndPos()
    return { math.random(400, 600), math.random(400, 600) }
end
--get selection
selection = octane.project.getSelection()[1]
print(selection)
--outLink = octane.node.create{ type=octane.NT_OUT_GEOMETRY, name="Output", graphOwner=selection, position=rndPos() }
--nodetest = octane.nodegraph.findFirstOutputNode(selection, octane.PT_GEOMETRY)
nodetest = octane.nodegraph.getOutputNodes(selection)
print("nodetest= ")
print_table(nodetest)
print("end----")
-- I have tried this.
    nodes = octane.nodegraph.findNodes(selection, octane.NT_OUT_GEOMETRY, true);
print("nodes=")
print_table(nodes)
    for i,entry in ipairs(nodes) do
        print(entry)
        for s=1,entry.pinCount do
                print(octane.node.getConnectedNodeIx(entry,s))
        end
    end
print("====ending======")
--[string "newgetselection.lua"]:23: attempt to index a nil value (global 'node')
--octane.GT_GEOMETRYARCHIVE
--PT_GEOMETRY
--NT_OUT_GEOMETRY
--p_INPUT
nodesfound = octane.nodegraph.findNodes(selection, octane.GT_GEOMETRYARCHIVE)
print("table:")
print_table(nodesfound)
print_table(obg)
print("endtable1")
outputnodesnames = octane.nodegraph.getOutputNodes(obg[1])
print_table(outputnodesnames)
print("end outputnames")
print_table(octane.node.getPinInfoIx(outputnodesnames[1], 1))
print("end outputnames info")
--octane.project.select(obg[1])
print("end selection print")
outlink:connectTo(82, outputnodesnames[1])
--octane.node.connectTo(octane.project.getSelection()[1],octane.project.getSelection()[2])
this is the cleaned up code
        print(i,n)
    end
    --print(str)
end
function rndPos()
end
Return to “Lua Scripting”
