Octane Network Render Node not starting up correctly.
sivertbakkeng
Network Render node doesnt fully start on my machine. I can still connect to and use render nodes from other computers on that same machine but when I try to start Render Node on it I get this - https://imgur.com/a/h2xStW2
Everything above the red line is what I get if I do nothing after starting the Node, the messages beneath the red line appear when I click the X to close the window once.
This used to work perfectly a few days ago, not sure how to approach this problem.
- I have tried downgrading NVidia drivers with no luck, am currently running same NVidia drivers as another computer on the network that has a functioning render node. Cinema and Octane / Otane Node all have two checkmarks in the "Allowed apps" settings for Windows Firewall.
Aleksei
Try to ask it in the RNDRToken Slack channel, there is a dedicated active channel for the node operators: https://app.slack.com/huddle/TEUDVSY1H/CETUMCGAD
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
what is the ID address+port of the Workstation Master?
Can you share a screenshot from a working Render-Node?
ciao,
Beppe
sivertbakkeng
Thanks for the replies, the problem seems to have taken care of it self without me doing anything : )
