OctaneRender™ for Blender 2022.1 - 27.11 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
  • Upgrade the color vertex implementation according to the changes of Blender 3.4
  • Enhance the material converter feature
  • Optimize the Orbx/Alembic export. Now the built-in image data will not be transferred repeatedly when exporting Orbx.
  • Added "Position" sockets in the Gradient Map node
FIXES SINCE LAST RELEASE
  • Keep the current position for nodes when duplicating Lights
  • Fix the OCIO UI traceback
  • Fix the rendering issue of the Open Subdivisions settings
  • Fix the real-time update issue of the subdivision settings & sphere attributes
  • Hide the unused compatibility settings in the kernel panel
  • Hide the shared surface panel and fix tracebacks
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.11 (3.4.1)
Octane Server - Studio+ Edition - 27.11
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.11
