World creator for octane crashes on Startup.
spartan00j
Hi, World creator for octane 2022.2.1 keeps crashing on Startup.
This is the message I keep getting.
03/04/2023 21:55:58 <Info> : Startup World Creator for Octane 2022.2.1
03/04/2023 21:55:58 <Info> : Available Graphics Devices:
                             NVIDIA GeForce RTX 3060 Ti
03/04/2023 21:55:58 <Info> : Microsoft Windows NT 10.0.19044.0
03/04/2023 21:55:58 <Info> : System Language: English (United States)
03/04/2023 21:55:58 <Info> : Graphics Device:
                             Vendor: NVIDIA
                             Name:   NVIDIA GeForce RTX 3060 Ti
                             Driver: 528.49.0.0
                             Memory: 8038mb
03/04/2023 21:56:00 <Error> : Failed to create delegate for function CreatePreviewRenderer (Type:CustomControls)
                              Exception: Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index')
                              Callstack:
                                 at System.Collections.Generic.List`1.get_Item(Int32 index)
                                 at WorldCreator3.Generating.Export.CustomControls.CreatePreviewRenderer(Control container)
                                 at WorldCreator3.Settings.Attributes.CustomControlAttribute.Create(IUIDataInfo propertyInfo)
03/04/2023 21:56:01 <Error> : Exception: Resource in slot 4 does not match ResourceKind.StructuredBufferReadOnly specified in the ResourceLayout. It must be a DeviceBuffer with BufferUsage.StructuredBufferReadOnly.
                              Callstack:
                                 at Veldrid.ValidationHelpers.ValidateResourceKind(ResourceKind kind, BindableResource resource, UInt32 slot)
                                 at Veldrid.ValidationHelpers.ValidateResourceSet(GraphicsDevice gd, ResourceSetDescription& description)
                                 at Veldrid.Vk.VkResourceFactory.CreateResourceSet(ResourceSetDescription& description)
                                 at Veldrid.ResourceFactory.CreateResourceSet(ResourceSetDescription description)
                                 at WorldCreator3.Generating.Export.OctaneExportPipeline.GetExportInfo(UInt32& width, UInt32& height, PixelFormat& outputFormat, UInt32& layers, ResourceSet& additionalResourceSet)
                                 at WorldCreator3.Generating.Export.ExportConvertPipeline`1.UpdatePreview(Texture tex)
                                 at WorldCreator3.Generating.Export.Export.UpdatePreview()
                                 at WorldCreator3.WorldCreator.Update()
                                 at WorldCreator3.WorldCreator.Initialize()
                                 at G7RUThn4yKElZQpcmJ.kFVwK8RZwemhBZ61W6.W3eX7ABr1(String[]  )
03/04/2023 21:56:01 <Error> : Last Recorded Actions:
03/04/2023 21:56:01 <Info> : Attempting to save current project
03/04/2023 21:56:01 <Error> : Failed to write thumbnail
03/04/2023 21:56:01 <Info> : Saved project backup to <C:/Users/spart/Documents/World Creator for Octane//Versions/2022_2/crash_backup_03_04_2023_21_56_01.wcr>
03/04/2023 21:56:01 <Info> : Closed after Error
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
nmkcompany
I had the same issue.
This is what I did. I uninstalled World Creator. Installed the latest version of Octane Standalone and Installed World Creator again. After doing this it worked again.
Maybe this helps.
Cheers
Sxcret
Sorry to bring back this post but I'm having the same issue.
Can't start World Creator for Octane 2022.2.1. Got the same crash error. I tried to uninstall it, install latest Octane Standalone and reinstall WC but still the same error. Tried aswell to start with Nvidia Gaming Drivers and Studio Drivers.
Can't find any solution to get it working again.
08/31/2023 04:46:51 <Info> : Startup World Creator for Octane 2022.2.1
08/31/2023 04:46:55 <Info> : Available Graphics Devices:
                             NVIDIA GeForce RTX 2080 Ti
08/31/2023 04:46:56 <Info> : Microsoft Windows NT 10.0.22621.0
08/31/2023 04:46:56 <Info> : System Language: French (France)
08/31/2023 04:46:56 <Info> : Graphics Device:
                             Vendor: NVIDIA
                             Name:   NVIDIA GeForce RTX 2080 Ti
                             Driver: 536.99.0.0
                             Memory: 11041mb
08/31/2023 04:47:05 <Error> : Failed to create delegate for function CreatePreviewRenderer (Type:CustomControls)
                              Callstack:
08/31/2023 04:47:07 <Error> : Exception: Resource in slot 4 does not match ResourceKind.StructuredBufferReadOnly specified in the ResourceLayout. It must be a DeviceBuffer with BufferUsage.StructuredBufferReadOnly.
                              Callstack:
08/31/2023 04:47:07 <Error> : Last Recorded Actions:
08/31/2023 04:47:07 <Info> : Attempting to save current project
08/31/2023 04:47:07 <Error> : Failed to write thumbnail
08/31/2023 04:47:07 <Info> : Saved project backup to <C:/Users/coren/Documents/World Creator for Octane//Versions/2022_2/crash_backup_08_31_2023_04_47_07.wcr>
08/31/2023 04:47:07 <Info> : Closed after Error
If someone has a solution I would be happy :)
Thanks !
please try to delete the user.cfg file under Documents\World Creator for Octane\Versions\2022_2.
If not enough, please write to help at otoy dot com.
ciao,
Beppe
Sxcret
bepeg4d wrote:Hi,
ciao,
Beppe
It worked !
Thanks a lot Beppe,
Have a nice week-end !
