100+ Modo | Octane Videos
Vaughan
You can access each of these videos from the Pixel Fondue Playlisthere:
https://www.youtube.com/playlist?list=P ... dTw9PGdTRp
I thought having the titles posted here would help in a forum search.
Enjoy!
Modo | Octane Render: Masking with Weight Maps
Modo | Octane Render: Color Correction Node
Modo | Octane Render: Texture Displacement Blurring
Modo | Octane Render: Render Passes
Modo | Octane Render: Round Edges
Modo | Octane Render: Distorted Mesh UV
Modo | Octane Render: Material Pick
Modo | Octane Render: Focus Pick
Modo | Octane Render: Material Group Alpha Render Pass
Modo | Octane Render: Render Region
Modo | Octane Render: Create Additional AOV Inputs
Modo | Octane Kernel Settings: Max Samples
Modo | Octane Render: Save Render
Modo | Octane Render: Background Image
Modo | Octane Render: Shadow Catcher
Modo | Octane Render: Stencil Layer Effect
Modo | Octane Render: Visible Environment
Modo | Octane Render: Modo Fur Material
Modo | Octane Render: Solo Node
Modo | Octane Render: Toon Material
Modo | Octane Render: Convert Materials
Modo | Octane Render: Delete Unused Nodes
Modo | Octane Render: White Balance Pick
Modo | Octane Render: Bloom and Glare Post Processing
Modo | Octane Render: Select All Nodes
Modo | Octane Render: Auto-Connect
Modo | Octane Render: Duplicate Octane Override
Modo | Octane Render: Instance Octane Override
Modo | Octane Render: Composite Material
Modo | Octane Render: Spectral AI Denoiser
Modo | Octane Render Viewport Navigation
Modo | Octane Render: Vignetting
Modo | Octane Render: Preview
Modo | Octane Render: Baking Texture
Modo | Octane Render: Incidence Angle Gradient
Modo | Octane Render: Polygon Side
Modo | Octane Render: Connections from Modo Channels
Modo | Octane Render: Gradient 2 Hidden Channels
Modo | Octane Render: Loading Live DB Materials
Modo | Octane Render: Color Vertex Attribute
Modo | Octane Render: Random Color Texture
Modo | Octane Render: Gradient Along the Length of Render Curves (W Coordinate)
Modo | Octane Render: Dirt Texture
Modo | Octane Render: Single-Sided Material
Modo | Octane Render: SubD Wireframe Render
Modo | Octane Render: Creating a Gobo
Modo | Octane Render: Texture Offset with No UVs
Modo | Octane Render: Distance to Locator
Modo | Octane Render: Digits Procedural Texture
Modo | Octane Render: Emissive Textures
Modo | Octane Render: Smooth Render Curves
Modo | Octane Render: Image Sequence as a Visible Environment
Modo | Octane Render: Composite Texture Node
Modo | Octane Render: Comparison Node
Modo | Octane Render: Comparison Node Using Item Location
Modo | Octane Render: Gaussian Spectrum Node
Modo | Octane Render: Cosine Mix Texture
Modo | Octane Render: Add, Multiply and Subtract Nodes
Modo | Octane Render: Light Linking
Modo | Octane Render: Clay Mode
Modo | Octane Render: Chaos Texture Node
Modo | Octane Render: Triplanar Projection
Modo | Octane Render: Invert Node
Modo | Octane Render: Environment Medium Fog
Modo | Octane Render: MatCap Projection
Modo | Octane Render: Field Texture Nodes
Modo | Octane Render: Planar Field Texture Locator Rig
Modo | Octane Render: Spherical Field Rig
Modo | Octane Render: Object Layer Color Node
Modo | Octane Render: Curvature Texture Node
Modo | Octane Render: Candle Flame Texture
Modo | Octane Render: Iridescent Texture
Modo | Octane Render: Chainmail Texture
Modo | Octane Render: Instance Color Range and Instance Color Nodes
Modo | Octane Render: Halftone Texture Effect
Modo | Octane Render: Clamp Texture Node
Modo | Octane Render: Capture to Custom AOV
Modo | Octane Render: Z Depth Texture Node
Modo | Octane Render: Channel Picker Node
Modo | Octane Render: Range Node
Modo | Octane Render: Instance Highlight Node
Modo | Octane Render: Proxy Workflow
Modo | Octane Render: Channel Inverter
Modo | Octane Render: Channel Mapper
Modo | Octane Render: Clipping Material
Modo | Octane Render: Nested Dielectrics: Material Priority
Modo | Octane Render: Auto-Connect Workflow Tip
Modo | Octane Render: Blackbody Emission
Modo | Octane Render: Texture Displacement Masking
Modo | Octane Render: Toon Shadow Ambient
Modo | Octane Render: Lenticular Effect
Modo | Octane Render: Suede Material
Modo | Octane Render: Ice Cube Creation
Modo | Octane Render: AI Up-Sampler
Modo | Octane Render: Baking Camera
Modo | Octane Render: Fisheye Lens
Modo | Octane Render: Metallic Material Presets
Modo | Octane Render: Orthographic Camera
Modo | Octane Render: Instance Position Projection
Modo | Octane Render: Camera Projection
Modo | Octane Render: Matching Modo Material Attributes
Modo | Octane Render: Vectron Node
Modo | Octane Render: Save and Load Octane Presets
Modo | Octane Render: Invalid Pin Connection Preference
Modo | Octane Render: Styrofoam Texture
Modo | Octane Render: Worn Edges Texture
Modo | Octane Render: Channel Merger
Modo | Octane Render: Ray Switch Node
Modo | Octane Render: Item Alpha Output
Awesome - thank you William.
Vaughan
New Videos added:
Modo | Octane Render: Contact Shadow using Black Layer Shadows AOV
Modo | Octane Render: Composite Output AOV Layer Mask
Modo | Octane Render: Cryptomatte Mask Output AOV
Modo | Octane Render: Layer Shadows AOV and Black Layer Shadows AOV
Modo | Octane Render: Light AOVs
Modo | Octane Render: Light Mixer
Modo | Octane Render: Render AOV Group and AOV Output Group Tip
Modo | Octane Render: Procedural Leather Texture
Modo | Octane Render: Render Flat Materials with No Shading
Modo | Octane Render: Custom Bokeh Map
Modo | Octane Render: Dispersion
Modo | Octane Render: Render Flat Materials using Toon Material
This thread is now "stickied"!
Obizzz
This is such a great resource and great idea to list them here to make it easier to get an overview if what you're looking for is covered.
I watched most of them earlier this week and learnt a few new tricks and got some reminders of stuff I had forgotten about.
Return to “Foundry Modo”
