Transfering all object to server bug
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Fredrikvictorhugo
I noticed a bug in Octane starting in the version Blender_Octane_Edition_2022.1_27.5_beta and forward when copying objects. Its annoying when handling a heavy scene. It works as expected in Blender_Octane_Edition_2022.1.XB4_27.4_beta. I post 2 videos showing the problem. In the first video all works fine using Blender_Octane_Edition_2022.1.XB4_27.4_beta.
https://www.dropbox.com/s/zgbmp7mit2uan ... 1.mp4?dl=0
https://www.dropbox.com/s/4uonxwqlg9i40 ... 2.mp4?dl=0
J.C
Same happens when:
1. Hiding/unhiding objects.
2. Adding new object
3. Adding new material
4. Editing an object
etc
All above was not an issue in previous versions.
System – Windows 11
linograndiotoy
Can you please provide some simple content showing the issue?
Also, can you please check if Persistent Data option in Cycles is actually off?
linograndiotoy
I've made a scene and I could reproduce the issue.
It only happens the first time you start the preview here, by the way. If you turn off the preview and turn it on again, everything works as it should. Could you please confirm that?
We'll look into that.
Fredrikvictorhugo
Hi!
It works as you explaned when turning preview of and on in Blender_Octane_Edition_2022.1_27.5_beta but in the latest build Blender_Octane_Edition_2022.1_27.10_stable it doesn't work. The Persistent Data is off.
My test scene is just cubes with subdivision on and copy them and after a while the problem shows. Like it has to do with how many objects you have?
linograndiotoy
Please try with the latest build, it should be fixed now.
Fredrikvictorhugo
Yes It works now :) Good job. Thanks
linograndiotoy
Sure!
Return to “Bug Reports”
