OctaneRender™ for Blender 2022.1 - 27.10 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
  • Add an "Auto Clamp Mode" option for the motion blur. Basically, OctaneBlender will only use the data between frame_start and frame_end to render the motion blur effect when "Auto Clamp Mode" is on.
  • Add a post-check to convert the Cycles Image node to the Octane Image node when adding a node by dragging files
  • Hide the old Object Data node and Camera Data node when using the Search option
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.10 (3.4.1)
Octane Server - Studio+ Edition - 27.10
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.10
