Octane 2022.1 for Unreal Engine - 0.64
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine
Changes:
  • Textures: Added option to load textures from the original source file (Option is in settings)
  • Export: Added option to export to OCS
  • Sequencer: Added option to export to OCS to the ORBX sequencer
  • UDIM: Added 8 bit single channel support
Fixes:
  • Stability: Fixed crash that could happen when setting the parent on an Octane Material
  • ORBX Import Conversion: Fixed rotation and scaling issues with fbx orbx files
  • ORBX Import Conversion: Fixed crash when ORBX uses FBX as geometry format
  • ORBX Import Conversion: Fixed possible placement duplication
  • Installer: Fixed issue where default install path was missing when proper install path was not found
  • Octane Material Editor: Preview window now updates when changing parent
  • Octane Material Editor: Correctly updates parent and textures on edited material
  • Stability: Fixed crash that could happen when switching levels in unreal
  • UDIM: Fixed crash
UE 5.1
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
UE 5.0
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
