Octane 2022.1 for Unreal Engine - 0.63
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine
Changes:
  • Geometry: Added Text Rendering
  • Lights: Added Attenuation range and non-inverse square law falloff
  • Decals: Greatly optimized decals in terms of generated shader code and rendering speed
  • Textures: Added support for Bink animated Textures
  • Viewport: Added simple timeline slider to the viewport that shows up when ORBX proxies have animated data
  • Octane ObjectLayerComponents now work on geometrycache components
  • Deferred Decal Materials now work on geometry
Fixes:
  • Stability: Fixed crash that could randomly happen when switching between scenes
  • ORBX Import: Imported textures are no longer kept in memory, reducing the chance of import failing due to lack of available RAM
  • Geometry: Fixed situation where material slots would be in the wrong order
  • Material: Fixed issue where decals would break because opacity is outside the 0 to 1 range
  • Material: Fixed several minor material conversion issues
  • Installer: Fixed issue where there would be no default install path
UE 5.1
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_1.exe
UE 5.0
Studio+ Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
