ACES/OCIO Settings Guide for Cinema 4D R2023
jayroth2020
For those of you using ACES/OCIO along with Cinema 4D R2023, we have put together a settings guide to get you going. Follow the instructions in the guide to set up your Color Management configuration in Cinema to see Octane renders correctly in the C4D Picture Viewer. If you have any issues with the information in the guide, please report in this thread.
Remember, this guide applies to Cinema 4D R2023 only.
https://help.otoy.com/hc/en-us/articles ... -Cinema-4D
SSmolak
Great guide but there is serious issue using gradient node which not work using OCIO color management - all materials are too bright while using gradient node.
jayroth2020
Thanks. Did you file a ticket for the gradient issue? [email protected] Please include any helpful support files in the report.
SSmolak
jayroth2020 wrote:Thanks. Did you file a ticket for the gradient issue? [email protected] Please include any helpful support files in the report.
Included all files. It seems that gradient is not linearlized ( wrong gamma ) using C4D OCIO
OCIO_gradient.zip
(1.15 MiB) Downloaded 214 times
jayroth2020
I believe that you have to have the Colorspace menu in Live Viewer set to OCIO<sRGB>. When set to that value, the output looks correct to my eye. Also you need to make sure that your Camera Imager is set up properly Octane Settings > Camera Imager > OCIO View should be set to ACES:sRGB.
SSmolak
No, this is not correct that only gradient node has problems between switching profiles. And yes, of course I have correct settings. Gamma 2.2 must be added to gradient to looks the same in OCIO.
KeeWe
Am I right that this only affects the display of the rendering in the picture viewer and other than that we are fine just using the build in aces checkbox in the camera imager?
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
I'm not sure why you're trying to use ACES profiles from C4D native. All you need to use just Octane OCIO settings from our sections. C4D OCIO side is completely ignored in the plugin.
SSmolak
aoktar wrote:I'm not sure why you're trying to use ACES profiles from C4D native.
Because it have little better viewport bright and color representation of materials.
james_conkle
Thanks for this guide - I've been meaning to update my default cinema config to use the new OCIO features inside cinema. Following your directions with the latest C4D 2024 & Octane plugin I noticed I need slightly different settings to achieve the same results.
In the "Set Up Color Management In Project Settings" settings I have to set "view transform" and "Thumbnails" to ACES 1.0 SDR-video for renders to display properly in the render view.
Will this have any adverse effects? The guide recommends using RAW for this.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
