OctaneRender™ for Blender 2022.1 - 27.9 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Support rendering the Octane Sphere Primitive for the Alembic
  • Added "Default Object Mesh Type" in the preferences panel
  • Added the picking option in the Object Data node
  • Added an Octane Node Converter in the Node Editor's right-click menu(Node Context Menu)
FIXES SINCE LAST RELEASE
  • Fixed the motion blur rendering issue when the camera is parented to a moving object
  • Added "Old motion blur behavior" in the Motion Blur panel to emulate the old motion blur effect
  • Assign the light to the Object Data automatically when creating Sun Light
  • Fixed the rendering crash when importing image textures to a new scene
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.9 (3.4.1)
Octane Server - Studio+ Edition - 27.9
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.9
azen
Hello,
In addition to the Studio++ builds, here are a the download links for the OctaneRender Prime versions of this current Test Build.The download links provided on the Prime Landing Page are for the most recent stable release - as with the Studio+ downloads on this post, the builds linked below are not considered suitable for Production work.
Windows
Octane Server Prime - 27.9
Linux
