Open Live DB not opening tab
Discussion forum for OctaneRender Cloud
SpiroBunster
Hi! I am having problem opening the tab of the "Open Live DB" in Octane because it doesn't appear, it's the only tab that doesn't open, for example if I click on the "Octane Node Editor" it appears inmediately, but not with the Open LiveDB.
Somebody knows what could be, or there is another way to open that tab?
Thank you so much! :)
ok, to share which version you are using exactly, please go to c4d menu Script/Console or Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
ciao,
Beppe
SWPMediaUnit
Hi! This has just started happening to me too. All was fine, but now when clicking on open live db nothing happens!
Using Cinema 4D 2023.1.3 (Build 2023.CL390584.49583)
Octane macOS 2022.1
Running on Macbook Pro M1 Max on Venture 13.2
Sorry, LiveDB is not available in OctaneX 2022.1.
It will come back with future 2023.1 version.
ciao,
Beppe
jaykats
Greetings,
I am running into the same issue! Do you have an estimation on when the 2023.1 version will be available?
Thank you for your time!
Kind regards,
Jay
JamesSamson
I also want to know when 2023.1 version will be available?
GJs
Live DB appears not to be working in 2023.1?
All the best
Dave
Yes, 2023.1 is out:
viewtopic.php?f=85&t=82234
But LiveDB is going to arrive with upcoming 2024.1 version.
For now, please have a look at this workaround:
viewtopic.php?f=7&t=75411&start=1520
ciao,
Beppe
mdreynes
Hi Beppe,
any news on LiveDB for C4D macos version.
I still cannot open the tab and no message appears in the console.
badapplefx
I'm now having the same problem, Live DB won't actually open in c4d 2025.1.3
Return to “OctaneRender Cloud”
