Please add option to Octane live viewer to make view without camera safe frames in free mode ( without lock resolution )
LiveViever - Clear view without Safe Frames
Whats UP if you disable it from scene settings?
Disabling safe frames affect only C4D perspective viewport and do nothing in Octane LV. The problem is more noticeable when we have set wide aspect ratio in render settings : It's hard to navigate with these borders...aoktar wrote:Whats UP if you disable it from scene settings?
yes "Safe frames" doesn't work but "Opacity" is doing the job.SSmolak wrote:Disabling safe frames affect only C4D perspective viewport and do nothing in Octane LV. The problem is more noticeable when we have set wide aspect ratio in render settings : It's hard to navigate with these borders...aoktar wrote:Whats UP if you disable it from scene settings?
YES ! Incredible, it works. Thank you for info. It should be in manualaoktar wrote: yes "Safe frames" doesn't work but "Opacity" is doing the job.
