Replace image breaks node connections
- rubberchicken
- Contact:
Might not be possible to do anything about this but when I use the shader tree etc to replace an image with another, a pretty common thing for me, the filename node is added but disconnected. An annoyance made all the worse by the positioning of the replacement node, it is a shame to spend half my time cleaning up the position of node placements.
Yes, this is a know issue, and definitely annoying. I will have another look into this problem, but from memory, the Modo Image, and the Octane Image are linked via the "Filename", so when the filename changes, the link is broken. It may be quite difficult to resolve.
