Scatter on surface only four pieces?
Houdini Integrated Plugin
gopper0815
Hello,
when i want to scatter a lot of pieces on a surface, i should use the scatter on surface node, right? But this node has only four slots for pieces. When i want to scatter for example a grassfield with ten or more different plantspecies, how do i this? And how can i use my own Attributes to scatter? I mad a testgeo (templatehead) and wanted to scatter ten different objects from Megascans on the head. I used the attriebutefrompieces and a scatteralign-node to distribute the pieces driven by a mask (maskbyfeature), so the pieces in the eyearea are smaller than on top of the head. How can i use something like this with the scatternode from Octane? Or even more than 4 pieces? And when i import a assetpack from Megascan, there are more than one piece in one geometrynode. They are delivered with splitnodes. But i can only select the geonode itself with the scatternode and Octane scatter only the first piece in the Node.
juanjgon
You should use the conventional Houdini instancing tools for this kind of scene. Instancing using the s@instance attribute or packed geo instancing are probably the best workflows.
Return to “Houdini”
