360 OctaneC4D fail
bbuxton_1
Octane panoramic & universal camera set to equirectangular is not rendering correctly. The vertical angle is less than 180 and there are black bars top and bottom of the renders. In fact none of the 360 camera projections are rendering correctly in Cinema4D and do not render correctly sent to Octane Standalone.
Rebuilding the scene in Modo with the same camera settings renders OK. I assume this is a bug in the Cinema4D plugin.
Sorry, which exact version of c4doctane plugin are you using?
Please go to c4d menu Script or Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
ciao,
Beppe
