OctaneRender™ for Blender 2022.1 - 27.8 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to Blender 3.4.1
  • Added "Primitive Coordinate Mode" in the mesh property panel - transferring the primitive data as the Octane coordinate or the Blender coordinate(previous setting)
FIXES SINCE LAST RELEASE
  • Fixed the metaball rendering issue
  • Fixed the copy/paste ramp node issue
  • Fixed the UDIM rendering issue
  • Added "$VIEW_LAYER$" to the default Octane output file settings
  • Hide the unused "Octane Output" menu in the Shader Editor
  • Enhanced and fixed issues with the Cycles material converter
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.8 (3.4.1)
Octane Server - Studio+ Edition - 27.8
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.8
