Why does my render keep crashing?
BadBilly
I have a scene that I just cant get to render.
I have rendered it before, no problem, I just updated a few small parameters. I have a few cameras in the scene, for different angles at different intervals (ie, camera 3 is say for frame 300-400) etc.
I can render all cameras except except the first 1, which strangely. crashes on the first frame. I have tried about everything - bug reports are attached.
Any ideas?
_BugReport.txt
bug report c4d
(828.28 KiB) Downloaded 103 times
bugreport_20230102_211549.zip
bug report octane
(1.59 KiB) Downloaded 82 times
We don't know why it crashes with this information. We can test it if you send your scene, or make more tests to have additional information.
:roll: you are using an outdated version of plugin, and the crash seems Nvidia driver related, but, let's try with a more detailed log first.
Please copy the attached “octane_log_flags.txt” file into ../plugins/c4doctane directory:
(106 Bytes) Downloaded 87 times
Then please, open a scene that is giving you issues, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
ciao,
Beppe
