OctaneRender™ for Blender 2021.1.7 - 26.6 Final Release [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
To maintain stability, this version only includes the new 2021.1.7, Blender 3.4, and some important fixes. This version does not include the addon-compatible nodes and features in the 2022 branch.
  • Upgraded to Blender 3.4
  • Upgraded to 2021.1.7
FIXES SINCE LAST RELEASE
  • Minor Bug Fixes
You can read about new features of OctaneRender™ 2021.1.7 here:
viewtopic.php?f=24&t=80911
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.6 (3.4)
Octane Server - Enterprise Edition - 26.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.6 (3.4) Linux
Octane Server - Enterprise Edition - 26.6 Linux
