Octane nodes spill into geometry nodes/cycles shader nodes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jan8
when in geometry nodes the octane nodes still litter the menu for available nodes, i.e. i can call octane nodes in geometry nodes. see attached screen grab
is this being worked on?
last tested in 2022.27.7
linograndiotoy
That's been fixed already.
AlexeyAdamitsky
I still expirience this issue with OctaneRender™ for Blender 2022.1 - 27.8. All Octane nodes are available in Geo Nodes search menu. This shouldn't happen.
Flyx
Same here, it's obviously not fixed or came back because of other change to the plugin
Win 11 64bits | Geforce 3090 RTX | RYZEN 9 5950X | 64GB
Flyx
The issue is still here on 27.10, this is important as it's cluttering the search menu wich is supposed to speed up the workflow...and if you made the mistake put a octane node in a "geometry node" node, it can crash.
AlexeyAdamitsky
I can confirm the crashing when you're using the node from the wrong context.
Return to “Bug Reports”
