OctaneRender™ for Blender 2022.1 - 27.7 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 3.4
FIXES SINCE LAST RELEASE
  • Fixed issues when using the new ramp nodes in world and light
  • Enhanced and fixed issues with the Cycles material converter
  • Refactored the blender's internal node-add to support the legacy octane nodes(but we still recommend using the new add-on nodes)
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.7 (3.4)
Octane Server - Studio+ Edition - 27.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
