Control From Dial
spartan00j
Paul,
Is there any way to implement the control from dial feature on more settings? Like maybe text your coordinates. Or even some render Target settings. Especially on the UV transitions. I just thought of a cool effect if I can animate the UV transitions attached to the texture under the displacement setting.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
I don't think this would be easy to implement, particularly the rendertarget dials. An (admittedly poor) workaround is to animate the setting in Octane Standalone, and then import that mesh into Poser as an ORBX proxy.
spartan00j
face_off wrote:I don't think this would be easy to implement, particularly the rendertarget dials. An (admittedly poor) workaround is to animate the setting in Octane Standalone, and then import that mesh into Poser as an ORBX proxy.
There's a way to animate the setting in Octane Standalone?
Win 11
128GB RAM
RTX 3060 TI
You need to start with an ORBX which has a timeline - and even then it's not simple. You would need to use an LUA tool such as viewtopic.php?f=73&t=55302. You are starting to hit the limits of what is possible in a host app such as Poser unfortunately.
Return to “Poser”
