OctaneRender™ for Blender 2022.1 - 27.6 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Enhanced the Cycles' Material Converter
FIXES SINCE LAST RELEASE
  • Fixed the rendering issue when using Compositing and Layered Material nodes
  • Fixed the corrupted ramp nodes when they are "appended" from other blend files(need to save the source blend file in the 27.6 again before appending)
  • Fixed a false warning when exporting the scene as ORBX
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.6 (3.3.1)
Octane Server - Enterprise Edition - 27.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
