Unreal 5.1 and Octane prim 0_59_UE5_1 failed to load
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
buzzmuff
I have the latest build of Unreal 5.1 official
I have then downloaded the latest version of the Unreal Octane plugin: OctanePrime0_59_UE5_1
https://secure1.otoycdn.net/plugindownl ... 82657133df
I have tried to install this Octane plugin in the UE5.1 folder. It seems to install normally and the Octane folder is created and filled with the required files inside the Engine\Plugins\ directory.
But when I launch unreal 5.1 I get the following error message:
"Plugin 'OctanePlugin' failed to load because module 'OctanePlugin' could not be found. Please ensure the plugin is properly installed."
What should I do to fix this is and make sure the OctanePlugin can load in 5.1 official?
ChrisHekman
The latest w9orking build is 0.61 here: viewtopic.php?f=132&t=80818
Unreal broke backwards compatibility in one of their 5.1 updates, which means older versions of the plugin stopped working.
Return to “Unreal® Engine”
